Newbies fireplace doors
发表于 2021-9-1 00:12:48 | 显示全部楼层 |阅读模式
Thanks to all those who helped with the thought process on these doors.  Hope the picture attachment worked.  I am addicted to this site!  They owner wanted to be able to take the doors off when needed.  So, they are removable!  Still need to insert glass and finish.  Anyone have a good site to share on different methods of finishing metal?Ben Attached ImagesLast edited by preeceben; 04-01-2007 at 09:56 AM.
Reply:Looks good. The Vice Grips are just to hold the two doors together for the photoshoot, right?  John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:Looks good..I'd wipe it down with some acetone..Prime..Paint with hi temp wroght iron black... ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Clean it, metal etch, and patina them. Search for metal finishes online, I am not sure of which books there are available. There are lots of finishes like gunbluing that have different coloration, look timeless, and are heat resistant.
Reply:Originally Posted by zapsterPrime..Paint with hi temp wroght iron black...
Reply:Nice, Is it made from 1/4 x 4  flat strap? Have it powder coated, tons of finishes to chose from.
Reply:looks good.how did you mount it to the rock?
Reply:looks good are you going to put wire mesh or glassin the doors
Reply:they turned out real niceLincoln 255XT Power Mig        Lincoln Precision Tig 225Hypertherm Powermax 30
Reply:Might look at this site;http://www.metallicfinishes.com/mfspage.html
GMT+8, 2025-12-23 04:05 , Processed in 0.093550 second(s), 18 queries .
