wall sconces
发表于 2021-9-1 00:12:46 | 显示全部楼层 |阅读模式
making wall sconces selling them on ebay Attached Images
Reply:They look really nice.  I hope you get some takers."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Very nice work. Good luck with that.
Reply:Nice job on those Ed.  What did you use to bend your round bar?......RichLincoln 255XT Power Mig        Lincoln Precision Tig 225Hypertherm Powermax 30
Reply:Looks nice.   Get rid of the welds.  Metal bands, rivets or weld underneath the bars prior to mounting on the strap or any other creative attachment method you can think of .  bevel the intersecting ends of the cross then grind flat Those beads,can me made invisible.  Make you stuff better than the mass produced import stuff. Good luck with with you venture.
Reply:i used a shop outfitter scroll benderi was thinking about a band tooim going to put this type to cover the welds Attached Images
Reply:Ed I think it will look good over the welds.  It will really give it an old world lookLincoln 255XT Power Mig        Lincoln Precision Tig 225Hypertherm Powermax 30
Reply:Edwhere do you get the cups to hold candles?   or do you make them..People are more violently opposed to fur than leather because it's safer to harass rich women than motorcycle gangs.  Unknown Pro Mig 175Hyphertherm 600Lots of toys at work
Reply:Ed,I have made a few similar to those.   I sat and looked at mine for some time and felt like something just wasn't right.   After "figuring" it out,   I heated and pounded flat the ends and shaped them  on the round stock.  On the flat,  I began to round the corners before I bent the material..It made a lot better looking finished product.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:architectural iron designs.com has a lot of themyou can get a catalog from them for free
Reply:they look really nice
GMT+8, 2025-12-23 04:05 , Processed in 0.067985 second(s), 18 queries .
