chain link gates
发表于 2021-9-1 00:12:45 | 显示全部楼层 |阅读模式
got a order for chain link gatesthere notched and mig welded not bent tubing like the onesat the home senters Attached Images
Reply:C'mon...let's see the closeup on the welds.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Nice ed mac.How many and how long to fab per unit?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Nice work.  I made a custom sized gate at our house.Miller Dynasty 200DX Tig Welder
Reply:I used to build those on a bigger scale at my last job. Hated grinding all that galvanizing off but if you didnt you just abought couldnt mig it. Got pissed off a few times and put some 6010s on it. Biggest I built was 6 foot tall and 40 foot long. A slide gate. Hope you got alot of those to do. They are money makers. Good work.AWS CWI/CWEASNT NDT Level 2 PT/MTAWS Certified Welder(aerospace)
Reply:nice job.look good.
Reply:I am in need of a notcher!American by birth Southern by the Grace of God
Reply:i went with a jd 2 notcher its HDyou can use a 1/2" hand drill Attached Images
Reply:That is a nice notcher what did it run ya?American by birth Southern by the Grace of God
Reply:Nice work. Nice notcher.Would there be any benefit to drilling and inserting the horizontal pipe into the veritical pipe?  Seem as it might be easier to lay out for welding.
GMT+8, 2025-12-23 04:02 , Processed in 0.092816 second(s), 18 queries .
