O/a question
发表于 2021-9-1 00:12:44 | 显示全部楼层 |阅读模式
Hi all Im looking to bend some metal stock (between 1/8th and 1/4") over a tube, in order for the metal to conform to the tube. Is there any other ways besides an O/a rig to ben the metal?ThanksDustin
Reply:What kinda metal stock is it?  square pipe, round solid, tube pipe.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:sorry, its flat bar
Reply:What is the reason that you don't want to use O/A torch? Given enough time you could get it done with a cheap mapp gas torch. You could get a bed of charcoal going and rig up a shop vac or leaf blower to make it burn hotter. However in most towns you could rent an O/A torch for the cost and cost of time in rigging something up. Is there some reason that it have to be bent cold?
Reply:no reasons against o/a, i just dont have one...thought maybe there was something else i could use
GMT+8, 2025-12-23 04:07 , Processed in 0.090367 second(s), 18 queries .
