gas backup tig welding
发表于 2021-9-1 00:12:43 | 显示全部楼层 |阅读模式
hi i want to try tig welding sheet metal today and make small box's with it do i need a gas backup for welding sheet metal if so whats the best way to make oneif you have one that you use could you please post pictures so i can get an ideathank you  Jason
Reply:Gas back-up on sheetmetal?... what you need is some aluminum to clamp the sheet too.. and use that as your "backup"..works every time.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:you arn't going to need backing gasChuckASME Pressure Vessel welder
Reply:so all i have to do is put the aluminum behind where im going to weld the joints and that's all i need.thanksJason
Reply:Originally Posted by RoosterBoyso all i have to do is put the aluminum behind where im going to weld the joints and that's all i need.thanksJason
Reply:thank you zapster i will post pictures for you tonight of the little box's im going to weld as practisethanks Jason
Reply:have fun! ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:well i got all the pieces setup put the welder in Low rage and turned it down some but i think i need thinner filler rod because i was able to fill some but it was melting the sheet metal faster then the filler rod. so i think i need thinner filler.i will buy some tomorrow when the welding supply opens but i got the sheet mettle clean and pieces cut so tomorrow will be the fun part welding them :-)thanksJason
Reply:for sheetmetal I would use .045 wire..70S-2...give that a try  ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Sorry... what's "gas backup"??  Is that like back purging (to shield the back of the weld)?.. I don't doubt it if using Aluminum is the answer.
Reply:yes it's back purgingChuckASME Pressure Vessel welder
Reply:Thanks.
Reply:While not ideal enough for a code weld you can use mig wire for filler if you cant find any tig filler that size.DennisThermal Arc 185-TSWMillermatic Challenger 172VictorO/AAtlas Craftsman 12 by 24 LatheEsab PCM-875Wholesalem Tool Mill-Drill
Reply:You say sheet metal, but sheet metal comes in all sorts of alloys?  Some don't need gas back-up (mild steel), some run better with back-up (stainless and aluminum), and some require it (titanium).  What alloy are you welding?
GMT+8, 2025-12-23 04:05 , Processed in 0.112584 second(s), 18 queries .
