ID cast steel
发表于 2021-9-1 00:12:40 | 显示全部楼层 |阅读模式
How do you tell the difference between cast steel/iron? I think I remember a guy telling me about the color of the sparks off a grinder but  that was a while ago. Thanks
Reply:Grinding cast iron usually gives of red sparks as opposed to white sparks with cast steel.Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:Originally Posted by gordon stephensonGrinding cast iron usually gives of red sparks as opposed to white sparks with cast steel.
Reply:Use a 1/8" drill somewhere on your piece where it don't matter and see what the chips do..If they stay kinda stringy then it's steel..All powder then it's Iron.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
GMT+8, 2025-12-23 05:52 , Processed in 0.092804 second(s), 18 queries .
