Pump mount
发表于 2021-9-1 00:12:38 | 显示全部楼层 |阅读模式
Here is a pump mount that I made the other day.  Because it was mounted against a wall, I had to drill holes big enough for the bolt head to fit into, then I welded it and ground it flush.  In the past I have tried to drill the hole big enough for the threads, and just plug weld the backside.  But with enough torque, it would just snap off. Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:Very nice welds.  Tell us more about the plate properties and machine(s) used.
Reply:Nice work Brainfarth.One question.  Is that motor designed for vertical mounting?  Some are, some aren't.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I dont know a thing about the pump.  The customer directed me to where and what orientation he wanted things. My welder was set the same as the other post: Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:Looks nice, whats the hydrolic system for?
Reply:looks good,  nice job on the weldsLincoln 255XT Power Mig        Lincoln Precision Tig 225Hypertherm Powermax 30
Reply:More nice looking stuff.It's nice to be able to weld continuously with the MIG.  No restarts."Any day above ground is a good day"http://www.farmersamm.com/
GMT+8, 2025-12-23 05:52 , Processed in 0.234617 second(s), 18 queries .
