A table
发表于 2021-9-1 00:12:36 | 显示全部楼层 |阅读模式
First, let me say that I've really enjoyed lurking around here for a couple of weeks. I'm really blown away by the technical skills and knowledge of people on this site. The projects are inspiring. And the criticism is not mean spirited.All that being said, here's a table I made a while back. 1/2 square bar and 1/4 flat. Attached Images"We live in an age when unnecessary things are our only necessities. "   - Oscar WildeMaxstar STL150Eagle CPM30 Bender
Reply:Lookin good.What is that finish? Textured paint?  Paint over rust? copper coated?A butterfly without wings, is just an ugly bug
Reply:First I coat it good with Rustoleum Metallic copper paint. After that cures, a light overspray (2 - 3 ft away) of Rustoleum Satin Black. It changes shades as the light hits it at different angles."We live in an age when unnecessary things are our only necessities. "   - Oscar WildeMaxstar STL150Eagle CPM30 Bender
Reply:I like how the welds look almost nonexistant.  Do you bevel, fill, then lightly grind?"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Yeah, I was always welding thicker stock than my little 110V Mig was meant for. So I figured out that bevel and fill strategy early on. When I discovered flap disks, it was manna from heaven."We live in an age when unnecessary things are our only necessities. "   - Oscar WildeMaxstar STL150Eagle CPM30 Bender
Reply:Great JobI may copy it!!How thick is the metal? That thing looks heavy.
Reply:Thank very much for the compliments.It's 1/2 Sq bar and 1/4 flats. I think it's about 20 lbs, maybe?"We live in an age when unnecessary things are our only necessities. "   - Oscar WildeMaxstar STL150Eagle CPM30 Bender
Reply:I my scroll bender can do 3/16" for sure. I do not think it can handle 1/4". I like the table alot.I guess this is another reason to make a ring roller.
Reply:I used my HF scroll bender to make jigs out of the 3/16. Weld them to an angle iron. Stick them in a vise and vise grip the hot 1/2 (or 1/4)  to it. Bend it and bang on it."We live in an age when unnecessary things are our only necessities. "   - Oscar WildeMaxstar STL150Eagle CPM30 Bender
Reply:I think HF has a ring roller for $150 right now. I can't see making one, unless you've got nothing but time..."We live in an age when unnecessary things are our only necessities. "   - Oscar WildeMaxstar STL150Eagle CPM30 Bender
Reply:I try to make my stuff (I never said I was smart)
Reply:nice work there are good people here
Reply:Are you going to make some matching pieces to go with the table?  A bench, loveseat or chair.
Reply:Looks nice
Reply:i th ink it will look fine made from 3/16 if thats what yer scroller can  bend...
Reply:Originally Posted by weldbeadi think it will look fine made from 3/16 if thats what yer scroller can  bend...
Reply:to me a mill edge is sheared. is a cut edge sharp on the corner? grind it..?
Reply:Originally Posted by weldbeadto me a mill edge is sheared. is a cut edge sharp on the corner? grind it..?
GMT+8, 2025-12-23 05:53 , Processed in 0.092433 second(s), 18 queries .
