Background current.
发表于 2021-9-1 00:12:33 | 显示全部楼层 |阅读模式
Could someone explain what this control is for on a tig machine?Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:Originally Posted by DoolittleCould someone explain what this control is for on a tig machine?
Reply:Background current is the low amp side of a pulse.  It should have the same range as the weld current.DennisThermal Arc 185-TSWMillermatic Challenger 172VictorO/AAtlas Craftsman 12 by 24 LatheEsab PCM-875Wholesalem Tool Mill-Drill
Reply:Yep, got it, had to go look at an older machine manual.  Mine didnt say a thing about it except 'its adjustable'.  thanks.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
GMT+8, 2025-12-23 05:53 , Processed in 0.085118 second(s), 18 queries .
