Lincon Welder Help
发表于 2021-9-1 00:12:31 | 显示全部楼层 |阅读模式
hi guys i got a lincon tig 300/300 code 8888-3 machinethe machine did not work at all and i replaced a resistor that go's to a transformer relay and now the stick part works fine. i have the schematics for the machine but need the schematics for the pc timer Bord's looks like there some stuff on the board that's fried but i can replace and fix that.and if i get the schematics my friend can reverse engineer the Bord's and get the tig part working and maybe even working better then how it was made :-) add some technology upgrade to it :-) be a one of a kind :-)if anyone has this info on the pc control Bord's id love to get it thank youJason
Reply:all is good called lincoln and now got the diagram should be tiging tonight
GMT+8, 2025-12-23 05:52 , Processed in 0.073003 second(s), 18 queries .
