stitch welding pipe
发表于 2021-9-1 00:12:22 | 显示全部楼层 |阅读模式
I recently viewed A picture of a pipe that was "stitch welded". Could someone please explain the technique ?
Reply:sometimes you run 1 root pass...sometimes 2..sometimes 3..Then you start on the bottom of the root..add a dip..go to the top...add a dip... move forward a little bit and repeat..without stopping... continue untill finished..its hard to describe... be better if i showed ya... ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Still unclear. Is there a site where I could maybe see it done?
Reply:Originally Posted by JLowderStill unclear. Is there a site where I could maybe see it done?
Reply:Just happened across this ad for a stitch welder, never seen nor heard of such a thing before, may be what JLowder posted about.http://cgi.ebay.com/Stitch-welder-Cu...QQcmdZViewItem
Reply:Thanks alot guys, I'll give it a try and send some pics.
GMT+8, 2025-12-23 05:51 , Processed in 0.067950 second(s), 18 queries .
