Table of MIG Wire Size - Feet on a Spool
发表于 2021-9-1 00:12:21 | 显示全部楼层 |阅读模式
How Many Feet of MIG Wire on a Spool?Once in a while I need the answer, so here it is.I provide one sample calculation (that you can ignore) followed by a Table for the common MIG wire sizes in steel, stainless steel (SS), aluminum and for reference - copper.Material Density------gm/cm^3----lbs/in^3Iron/Steel------------7.7--------0.27812Stainless Steel ------8.0--------0.28896Aluminum--------------2.7--------0.09752Copper----------------8.9 -------0.32147Sample CalculationHow many feet of 0.035 inch diameter mild steel wire in a 2 lb spool of MIG wire?Density conversion factor: 1 gm/cubic cm = 0.03612 lbs/cubic inch Density of steel = 7.7 gm/cubic cm or 7.7 x 0.03612 = 0.27812 lbs/cubic inch2 lbs of steel wire has a volume of 2 lbs / 0.27812 lbs/cubic inch = 7.191 cubic inches.Wire of 0.035 inch diameter (D) has a cross-sectional area of = pi/4 x DxD = 3.14156/4 x 0.035 x 0.035 = 0.000962113 square inches.Wire Volume = Wire Length x Wire Area.Wire Length = Volume/Area = 7.191 / 0.0009621 = 7,474.3 inches or 622.8 feet.Formula: Wire Length = [weight of wire (lbs) / density (lbs/in^3)] / [3.14159/4 x Diam^2 (inches^2)]TABLE: FEET OF MIG WIRE ON A SPOOL (Solid Wire, not Flux Core)Wire Diam---Spool--Steel----SS------Aluminum---Copper(inches)---(lbs)---(feet)--(feet)---(feet)-----(feet)0.023--------1-------721------694-----2056-------6240.023--------2------1442-----1388-----4112------12480.023--------10-----7210-----6940----20560------62400.023--------44----31724----30536----90464-----274560.030--------1-------424------408-----1209-------3670.030--------2-------848------816-----2418-------7340.030--------10-----4240-----4080----12090------36700.030--------44----18656----17952----53196-----161480.035--------1-------311.4----300------888-------269.40.035--------2-------623------600-----1776-------5390.035--------10-----3114-----3000-----8881------26940.035--------44----13703----13189----39080-----118550.045--------1-------188.4----181------537-------1630.045--------2-------377------362-----1074-------3260.045--------10-----1884-----1810-----5373------16300.045--------44-----8289-----7978----23640------71720.060--------1-------106------102------302--------91.70.060--------2-------212------204------604-------1830.060--------10-----1060-----1020-----3022-------9170.060--------44-----4662-----4488----13298------4034Rick V
Reply:Good info Rick.Based on wire feed rate and arc time, or on weld joint volume, you can figure how much wire you're using in lbs or feet.
Reply:Hey Pulser, your are right... and once in a while folks tell us tales of how many lbs per hour they were laying down.Not only that, the Table is interesting/useful if a fellow takes the time to measure (calibrate) the wire-speed at various settings of his welding machine.e.g.Here is the Wire Feed Measurements from my Lincoln Mig PAK 15 (SP-175T)Setting       inches/minMin…………….  481……………….  512……………….  903……………….1404……………….1905……………….2656……………….3207……………….3808……………….4409……………….50010……………..560Max…………...563Question: If my welder was loaded with a new 2 lb spool of 0.023 inch diameter steel MIG wire, I could weld continously at setting #4 for how long?According to the Table, 2 lbs of 0.023 = 1442 feet or 12 x 1442 = 17304 inches.Setting #4 = 190 inches/minuteTherefore, number of minutes = 17304 / 190 = 91 minutes or about 1.5 hours.How much gas would I use?  If I were running a typical gas flow of 15 cubic feet per hour, I would use/need 1.5 hours x 15 ft^3/hour = 22.5 cubic feet.The range of my welder settings, maximum speed to minimum gives me from 1/2 hour to 6 hours continuous welding from a 2 lb spool of 0.023 solid wire.Rick V
GMT+8, 2025-12-23 05:53 , Processed in 0.068008 second(s), 18 queries .
