stick weld backing bar, chill bar
发表于 2021-9-1 00:12:21 | 显示全部楼层 |阅读模式
What is good to use as a backing bar or chill bar? I preferably want one that I can grind off, basically for use with thin metals. Tired of burning holes when the arc wanders
Reply:Use brass, then you won't have to grind it off.  Aluminum works too but brass is better.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Copper plate. Pricey as heck.
GMT+8, 2025-12-23 05:49 , Processed in 0.071605 second(s), 18 queries .
