I need to weld several stainless steel bolts to mild steel angle iron. Can this be done with TIG. If so, should I use SS filler rods or mild steel filler rods.
Reply:doesnt really matter cause ure using mild steel anyway. short answer yesI forgot how to change this.
Reply:I would recommend E309 filler wire.
Reply:^^^What he said.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:OOPS...I meant ER309
