Marvel Schebler carb question
发表于 2021-9-1 00:12:17 | 显示全部楼层 |阅读模式
I have a marvel schelber carb on my sa-200 short hood and I got fuel coming out of the of air intake side when I turn on the fuel. Need some input. Is probably my best to tear it down and soak it carb cleaner for 24 hours and then blow out with air compressor and then throw a rebuild kit in it? The part number I got is 2-1401 napa is the the correct rebuild? I finally got the motor running at 2am this morning after rebuilding the magneto and cleaning fuel tank out (all kind of goodies in there). I noticed that on my raditor my top hose is really hot to the touch were my bottom hose it cool. So I think my thermostat is stuck and not letting coolant in cause in began to drip coolant out of the top connection (which is tight). I have not took a look at the thermostat yet but if any one has a NAPA part number for the thermostat would be very helpful. I plan to head to NAPA in few hours.Details: Lincoln SA-200 code number 1827 Continental F-162        Scott
Reply:If fuel is coming out the air intake then your float is stuck down..Sometimes just a tap or 2 with the plastic end of a screwdriver will un stick it.Top hose hot and bottom cold = stuck closed thermostat.Seems like everything is stuck.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:What Zap said, although I had a problem with a Harley carb that the float wasn't stuck, but had some crud on the valve seat. The end result is the same though.That whole scenario was caused by a local station that didn't properly prep their tanks for ethanol fuel and it gummed up the whole fuel system.PapaLincoln Idealarc 250 (circa 1962)Lincoln Weldpak 155 w/Mig KitLincoln Squarewave TIG 175
Reply:Thank you Zap and papa. Yeah this welder has been setting for a while. Ill post some pictures when I get everything squared away. It was the best you can here this morning at 2am. Fired right up with that rebuilt mag.        Scott
Reply:Got the thermostat housing and thermostat out. Still in need of a part number for a shorthood thermostat if anybody has one it would be great help thank you
Reply:If it doesn't have it you should install a fuel shut off valve. Just shut the gas off when it is not in use, problem solved. To fix it totally just install a new needle and seat, or carb kit.
Reply:Any decent auto parts store can match the T-stat from measuring it.  Flange dia and height is about all they need.
Reply:Then, when you get a match, you can post the number.Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:Originally Posted by NiteskyThen, when you get a match, you can post the number.
Reply:Many T-stats have a number stamped into the flange.... should have mentioned it earlier.  And it's very unusual for one to stick closed...  If they fail through corrosion they stick open as they're designed to remain open if the thing fails... likely just some gunk on the shaft the plunger rides on keeping it from opening.  May be able to just clean it up.  Of course nobody knows who stuck what in there at some point in its life.
Reply:I tried to clean up the thermostat but it looked someone had already been there and a metal piece around the plunger is broke off. I went 2 napas this morning and nobody was no help. I am going to have to do some more looking and calling to get a part number.
Reply:http://hybriweld.com/products/thermo...28e8009af51e56Or, call Kaye 405-232-4799Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:orlieys part number 3008 is what i used and seems to be running nice and cool!
Reply:thank you everyone for your help.
GMT+8, 2025-12-23 07:18 , Processed in 0.094195 second(s), 18 queries .
