查看: 2|回复: 0
car trailer
发表于 2021-9-1 00:12:16 | 显示全部楼层 |阅读模式
a while back while work was still quiet the boss got one of the tradies to replicate a hire car tralier, took him about a week and a half to make, 2 days of welding, then it got sent away to get painted and came back ready for me to checker plate it, turned into one bloody expensive trailer.anyways here's some photo'spersonally i would have left the front center checker plate panel off but oh well.
Reply:Nice job.  What is the checker plate material?  How does it affix to the frame and fenders?Thanks
Reply:Looks good!  How much did cost to build?  I think that the inside of the wheel wells need to be covered.Carlohttp://public.fotki.com/Naudi2U/
Reply:Nice looking trailer. I think your right about the center piece. Use it for the inside of the wheel wells and put expanded metal down the center. Let the oil and such drip on the ground and not on that nice shinny plate.   Ranger 8 3200HD 225 Cracker Box
Reply:Very nice work. But your right about it being expensive. Unless you have the materials on hand, a good design to work with and the spare time on hand it would be easier to just buy it. If you can get one at a reasonable price.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Originally Posted by geezerNice job.  What is the checker plate material?  How does it affix to the frame and fenders?Thanks
Reply:Quality job.  Too nice to get dirty isn't it?Hey - My 100th post alreadyLast edited by Nitesky; 03-02-2009 at 06:08 AM.Reason: My 100th postGordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:yeah, its mainly going to be used for the boss's speedway car so its defently going to see some mud
Reply:why so many crossmembers on the runners. dang nice by the way.
Reply:its amazing how these little "government projects" that are originally intended to save money end up costing way more than just buying one ready made.   but look at it this way now he doesn't have to modify a new one it should be exactly what he wanted.looks like a nice piece of kit though.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Nice setup.  You dont see that type of aluminum around much.  Makes me want to build one, but it would be flashier than my vehicles.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Very nice.  What is the round tube framework mounted under the tongue going to be used for?The winch post looks like it could use some bracing to the rear.I agree, covering the inside of the fenders would be a good idea.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:the rolled pipe at the front will be like wheel blocks
GMT+8, 2025-12-23 05:49 , Processed in 0.098349 second(s), 18 queries .
