some stuff i made
发表于 2021-9-1 00:12:16 | 显示全部楼层 |阅读模式
Ok heres a few things I am working on. I built a panhard bar for my mustang, this allows me to remove an upper control arm and relieve some bind in the suspension. Dont mind the high performance paint job. I may have some tweaking to do with the height of the bar and such, well see. I also didnt plan on using the square tube funky bar but I was kind of in a hurry to get it together, I want to replace it with a "swedged" aluminum rod later. And a little 4 point cage I made for the inside. The camera defintely brings out the ugly in stuff, the bar isnt really rusty but the picture makes it look like its been in the rain for a year. I am not good at painting so some day ill try and mask it all off nice and paint it good. Also had to use my friends welder on this one worked good miller 175. At the moment I am waiting for parts to build my lower control arms.... Attached ImagesLast edited by fordman; 03-05-2009 at 12:33 AM.HTP Invertig 201Lincoln Idealarc SP250Miller 180 AC StickBy farmall:They should have held the seagull closer to the work, squeezing evenly for best deposition.
Reply:If you want to paint that bar up decent without the hassles of masking everything in site, just brush on some rustoleum. It'll look 1000% better and it's pretty hard to screw up the application!
Reply:Hell, that doesn't look bad at all......... the weldingIf you use a good enamel FLAT BLACK, you can do it with a sponge brush and it'll look really good"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Nice,Lets see some pics of the car. I like stangsAmerican by birth Southern by the Grace of God
Reply:great work
Reply:Originally Posted by 74fencerNice,Lets see some pics of the car. I like stangs
Reply:Hey Fordman,I'll have to send your pics to my friend who has a Millermatic 175 but has hardly used it at all.  Not bad!! ScottMiller XMT 350 CC/CV w/gas solenoid opt.Miller S-22A wirefeederBernard 400A "Q" gunMiller Spoolmatic 30A / WC-24C-K 200A torch/gas lensWeldcraft WC-18 watercooled torchHypertherm Powermax 30Victor O/A
GMT+8, 2025-12-23 07:18 , Processed in 0.094159 second(s), 18 queries .
