Vice Stand
发表于 2021-9-1 00:12:15 | 显示全部楼层 |阅读模式
Been lurking here for some time and now it is time to start making a conribution.  Here is a vice stand that i made recently.  It has a 15mm base, 12mm top with 100x100x6mm post. TIG welded (practice).Root - 195amps DCEN, 2.4 Lanth. 100%arg.Cover - 180amps DCEN Attached Images
Reply:Hey Welcome Larry,  those are some nice looking welds.  I can't quite figure out the vice though, do you have another angle of it?
Reply:Thanks for the welcome.  Its a 150mm offset vice made by Record.  New perchace for me as i am sick of ttrying to hold thing with my feet/hands and getting burned or cut.   Attached Images
Reply:I see the reason for the offset.  That's pretty neat.The welds look a DARN(so it won't be confused) sight better than what I accomplished today."Any day above ground is a good day"http://www.farmersamm.com/
Reply:nice welds and cool vice I might try build one
Reply:Originally Posted by norsky63nice welds and cool vice I might try build one
Reply:Makes holding long things easier.Welding tech learned through practice and all of the welding tech discriptions given in this forum.  There are some great welders here.................thanks
Reply:That is a cool vise, haven't seen one like it before.
Reply:Originally Posted by GLwelderThat is a cool vise, haven't seen one like it before.
Reply:Looks good LarryO I have a very similar vice and setup to that out in my shop.SimonLabel EverythingMetal Fabrication - Welding Repairs - Wrought Iron - Sign Writing - Custom Decals.
Reply:That's quite a vise. And the stand isn't too slouchy either.
Reply:neat way to keep the hammer handy...
GMT+8, 2025-12-23 05:56 , Processed in 0.138204 second(s), 18 queries .
