Something sorta Constructive
发表于 2021-9-1 00:12:14 | 显示全部楼层 |阅读模式
Instead of raking the muck, or mucking the rakeFigured I ought to put something constructive up.All brackets for 3pt hitch finally installed.  ALONG WITH 11, COUNT 'EM, 11 TARP TIEDOWNS.  Some folks have cupholders, I have tarp tiedowns Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammInstead of raking the muck, or mucking the rakeFigured I ought to put something constructive up.All brackets for 3pt hitch finally installed.  ALONG WITH 11, COUNT 'EM, 11 TARP TIEDOWNS.  Some folks have cupholders, I have tarp tiedowns
Reply:Just a suggestion, Samm. I'd try to "soften" those top corners for the tarp. That looks very good and I bet it will be nice to hook it up to the tractor and go anywhere you want w/ it.                                  MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Lookin good Samm!I that a cat-1 or cat-2 hitch size?#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:Originally Posted by Ken DennisLookin good Samm!I that a cat-1 or cat-2 hitch size?
Reply:Wow!! Nice to see its coming along on that project. I know I always have a hell of a time doing the placement & fitting of the 3Pt brackets. My Cat2 always seems to be just a bit off center but the Cat3 seems to always have to be dead on center or the 3Pt  when lifting will distort the bracket plates.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:So where's the tractor - we wana see you lift it.A butterfly without wings, is just an ugly bug
Reply:call it a ton and be done..congrats on the design and build.:
Reply:Good lookin' job Samm, what color you gonna paint it?
Reply:Hello Samm,                 Really nice project,I like it a lot. That thing will still be above ground when we've all long gone,  Regards  Gordon.
Reply:Originally Posted by specterWow!! Nice to see its coming along on that project. I know I always have a hell of a time doing the placement & fitting of the 3Pt brackets. My Cat2 always seems to be just a bit off center but the Cat3 seems to always have to be dead on center or the 3Pt  when lifting will distort the bracket plates.
GMT+8, 2025-12-23 05:53 , Processed in 0.094246 second(s), 18 queries .
