profax spool gun
发表于 2021-9-1 00:12:10 | 显示全部楼层 |阅读模式
I am looking at a profax spool gun and would like your opinion on them.  I have just recently started using a profax whip due to it being on the welder I just purchased.  It is new and I will give it a run for it's life.  I am told the profax whips are built like tanks; we will see.My other option for a spool gun is to hold out and buy an ESAB ST-23A.What are your experiences with profax?  Good/Bad?  The LWS around the corner is loaded to the gills with Profax consumables.  I guess I am hoping responses will be good due to convienence. But, that doesn't matter much, I buy in bulk and stock up and will order off the internet.
Reply:They are great guns  The ESAB ST23A  is a Profax AEC 200.  its made by profax for esab.   they have a gas valve in the gun itself so your gas supply is instant instead of being turned on and off at the machine.  You can also get control boxes to run them directly of any   CC or CV Machine.   they are also 100% made in the USA and when you call customer support u get a live person who has be very helpful at least when I have called them.   If you get the non esab branded one and want to hook up to a migmaster, the plugs are available from Mouser electronicsthe part number for the plug is654-MS3106F18-8P  they were on back order but just shipped mine and have 8 more listed in  stock,   about $34.   less than half of ordering from esab/profaxTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:oh there are 2 different motor s available for the non solid state versions.  I recommend calling Profax and ask them what is best for your intended usage.  I had one of each and currently have the slow one, 36:1 ratio I think rated for .030 to 3/64 wire.,   the 64:1  is .035 to 3/64 wireLast edited by soutthpaw; 07-26-2011 at 11:11 AM.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:I am looking at the 36:1.  thank you for your replies.
Reply:Talk to Glen Rohan at Profax (800-594-3958).  I believe he's the main contact for the spoolguns but if not Christie or whoever answers the phone can direct you to who would be the best to address any questions.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I used one for a couple of years at a job a while back.It worked well, & was pretty tough.It's probably what I'll end up buying eventually myself.Buy American, or don't whine when you end up on the bread line.
GMT+8, 2025-12-23 05:56 , Processed in 0.098867 second(s), 18 queries .
