x-member mod....rack and pinion conversion
发表于 2021-9-1 00:12:06 | 显示全部楼层 |阅读模式
this is the start of a rack an pinion conversion on my project car.  The cutout is for the steeering shaft to run through.   Im welding in some internal stiffening plates to give extra support.here are some pics....more soon. Attached Images
Reply:Glad I noticed you were an Aussie.  I was about to say, "You're on the wrong side!"
Reply:My first thought was, "OMD, he's got the rack and pinion upside down!"!Then I noticed you're from Oz.Looks good so far.Rex
Reply:Why is it called "Oz"?Thanks"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by farmersammWhy is it called "Oz"?Thanks
GMT+8, 2025-12-23 05:54 , Processed in 0.088666 second(s), 18 queries .
