Industrial shelves
发表于 2021-9-1 00:12:04 | 显示全部楼层 |阅读模式
Hello,First off sorry if this is in the wrong place.I am looking for the metal material used in building heavy duty shelves, such as the kind you would see when you walk into lows or homedepot. Not sure what the correct name for it is, that metal angle iron with the holes in it to allow for adjustment for the shelves.  I have a lot of heavy duty wood and was wanting to build nice shelves like you would see in those stores.  Dont want to let this wood go to waste.looks similar to this.http://www.sears.com/shc/s/p_10153_1...4680000P?mv=rrthanks, brent
Reply:Go to eBay or Craigs list, look for pallet racking, industrial shelving, etc. You can't possibly build it cheaper than it sells for there. Most stuff starts at 12' high. There are many different styles and they don't usually work with each other.Just my  opinion, not from a book, just from the road.Howes Welding Inc.www.howesweldinginc.com
Reply:Originally Posted by tessdadGo to eBay or Craigs list, look for pallet racking, industrial shelving, etc. You can't possibly build it cheaper than it sells for there. Most stuff starts at 12' high. There are many different styles and they don't usually work with each other.
GMT+8, 2025-12-23 05:51 , Processed in 0.092372 second(s), 18 queries .
