Weekend Project-Cart
发表于 2021-9-1 00:12:04 | 显示全部楼层 |阅读模式
Got this cart at a garage sale, cleaned up some scrap, added bottle holder. Things are just temp. mounted but looks like it will work out OK. Only problem is I may have to add a counter balance, the bottle tilts the cart a little, but other than that, I can now move it where I need to in the shop. Attached Images
Reply:2nd set of pics Attached Images
Reply:lookin good what if you built a shelf off the other end same height as the middle shelf for the welder should be counter balance enough then you would have the whole cart to weld store things on
Reply:just move those wheels by the tank to under the tank you'll be good togo. It's not what you can buy, it's what you can build that matters
GMT+8, 2025-12-23 05:54 , Processed in 0.082025 second(s), 18 queries .
