Seems to Work
发表于 2021-9-1 00:12:03 | 显示全部楼层 |阅读模式
Walking beam seems to do the job balancing the load(well empty right now).  It can be moved any direction to counteract any load condition.  The eye also moves.It won't stay on the skid.  It's removeable.  Pull the pins, and take it off and store it.Finished up late.  Still need to make a latch for the loading ramp, and a restraining bar for the torch cart.  AND MOUNT THE STUPID WELDERAppologies to Cataract Man for not cleaning the weldsThe beam is the only 3/16 wall tubing on the entire thing.  Rest is 11ga.  Main welds on the beam(vertical plate) were 7018.  Stiffeners(1" strips) were 6013(I got the better part of a 50lb box to get rid of)It's coming together finally.  I hope it works out.  That crashing sound you hear might not be the economy Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:That looks mighty good, Samm!!! Even w/ 11 ga , I don't think you could pack enough weight on it to break it. Good job, now go have a couple of cold ones to celebrate completion .                             MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Looks like you've thought of everything. What's your guess on loaded weight?
Reply:Samm:Nice angles and dangles. I like the walking beam, covers all load situations. Did you draw any of that, like on a CAD? Or a napkin? Or did you build as you went? 9-11-2001......We Will Never ForgetRetired desk jockey. Hobby weldor with a little training. Craftsman O/A---Flat, Vert, Ovhd, Horz. Miller Syncrowave 250
Reply:Nice... Good job... Now u desrve a big gulp of beer...Unit in my fab shop dept:my good hand and team that trust me...A lone welder make art... a village full of welder make Miracles...
Reply:Originally Posted by SandyLooks like you've thought of everything. What's your guess on loaded weight?
Reply:Originally Posted by MandauNice... Good job... Now u desrve a big gulp of beer...
Reply:Craig--- It's mostly in the head.  I don't know if that's such a good thing.  I think it costs a lot of time when you run into something that you didn't think about.  Drawn plans would allow you to make a "fix" before you run into trouble.When I built the front end loader for the tractor it took about 2 weeks of drawing, and redrawing, to come up with the final print.  But it was really only a matter of cut and glue from there on out.As I get older, and my time is spread over other things, I tend to take shortcuts which really aren't shortcuts when you sit and think about it."Any day above ground is a good day"http://www.farmersamm.com/
Reply:To be honest with you, the thing I'm more concerned about is how the 3pt setup will handle the leverage as the tractor bounces. It gets pretty rough on unpaved ground.
Reply:Looks really good Sam.A butterfly without wings, is just an ugly bug
Reply:Originally Posted by SandyThat's all I was thinking about, is what ever you decide to put this on or carry it with at different times.
Reply:This area here.  Top and bottom flange plus the spine on stress side of the beam Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Really nice job Sam.Looking forward to seeing it painted, loaded and hooked on the back of Ollie!MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by farmersammI think the tractor will handle it, the lift is rated at 4000.  I just hope I designed the skid right.  I reinforced the connection at the base of the floor where it meets the uprights, then added a top and bottom flange to the tubing to the point where the welder mount ends.The first time I take it over rough ground I'll probably get a really bad neck/shoulder cramp from looking back to make sure it's still there
Reply:Nice work SammBut I'm lost. What is it?
Reply:Originally Posted by denrepNice work SammBut I'm lost. What is it?
Reply:duane how much time did it take you to get all those together? some of ya'll got way too much time on hand.  go weld somethin
Reply:Originally Posted by fishon91duane how much time did it take you to get all those together? some of ya'll got way too much time on hand.  go weld somethin
Reply:Sam the only concern that I have is that when you load this thing down and try to lift it your lifting point may slide on you. Make sure it’s in places and secure. If it slides on you, you may have a very bad day. Just a thought I would try wood wedges or something to hold it place. Looks real good.I carry guns because cops are too heavy. .. ..-.   -.-- --- ..-   - .... .. -. -.-   .... .- .-. -..   . -. --- ..- --. ....   -.-- --- ..-   -.-. .- -.   ..-. .. --. ..- .-. .   .- -. -.-- - .... .. -. --.   --- ..- -
Reply:Or,To keep it from sliding,   drill a hole and weld a nut onto the hole and put a bolt on it to be able to tighten down the adjustment.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Hi, Samm,               I thought about the sliding problem a while ago, Another solution could be to add a little weld to the top side of the thr'o pins then dress them to turn the pins into cams,or maybe just put a bend in the pins to get the same effect,   Just my two pence worth !!!  Best regards  Gordon.
GMT+8, 2025-12-23 05:51 , Processed in 0.106165 second(s), 18 queries .
