Got my Dynasty, can't believe what I'd been missing!
发表于 2021-9-1 00:12:01 | 显示全部楼层 |阅读模式
Got my Dynasty all wired up today. Put a 230 plug on the end and made up a 230-120v adapter cable. Well I figured I'd give it a shot on a 120v-20a circuit and see what happened. Wow! This thing is a great tool. I pulled out a piece of .090 aluminum and laid a few stringers down. Maybe because I was so used to the old 400a Airco w/hi freq, I had polished my technique a little and this is just the topper. We dabbled with the different parameters like balance and freq., and even used the pulser, and sequencer to ramp down at the end to do a crater fill. We even had it to 150a to run some on 1/4 al. The icing on the cake was that we plugged it into a similar circuit off of my 5500w trailer gen and it performed just as well. All I can say to anyone that is considering this machine, you will not be disappointed. And the contractor kit is a nice way to be up and running quick.
Reply:Very cool. Dynasty 200 series, 300 series or 700 ?John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:200dx
GMT+8, 2025-12-23 05:53 , Processed in 0.069019 second(s), 18 queries .
