5,4,3,2,1.......
发表于 2021-9-1 00:11:52 | 显示全部楼层 |阅读模式
WE GOT LIFTOFFPut the load on it, and put it on the truck.  3pt. test comes tomorrow.  Got carried away with celebratin' the first testOldtimer said "Build it, and quit talkin' about it".  Denrep wondered what it was.  And Y'all are just about fed up with seein' itThe toolbox is sized accordingly for the right after work refreshmentsSome particulars to follow............ Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Some details of how the cutting rig is secured.  Won't be transported with the regulators on. Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:How'd the truck set with it?  Good to go?
Reply:Looks like all it needs now s BLUE paint.A butterfly without wings, is just an ugly bug
Reply:FUBAR'D THE THIRD POSTFits well between fender wells on both trucks.  Only tested it on the 1/2 ton F-150.  Bein' a fan of American built iron, I thought it handled a pretty good overload well.  Dodge has too much crap in the back to put the doggone thing on it.  50" wide, fits all domestic beds, I guess.Squatted the ol' Ford a bit, but try that with a Tundra Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Originally Posted by Magnetic MechanicLooks like all it needs now s BLUE paint.
Reply:Purddy slick! You know, in the other thread I thought it looked huge, like a gorilla cage or something. Samm, we need to get a forklift, or at least a three-point mast, on your to-do list.Good Luck
Reply:Originally Posted by duaneb55Sam, I canNOT believe we have to wait until tomorrow to see it on Olie!!Looks good on that almost Miller blue truck too.
Reply:She's a work of art Sam, good to see your baby take flight.If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:Now I KNOW I have lived in Wisconsin for too long, I saw that f-150 and was absolutely shocked that it wasn't completely rusted out."But....but wheres all the rust? wtf? when was that picture taken?"Yup
Reply:Nice rack for the BEER.  But, whats all that welding/cutting equipment doing  there. ????Last edited by Roy Hodges; 03-18-2009 at 12:52 AM.Reason: editing ![SIZE="5"Yardbird"
Reply:You did a fine job on the rig Samm. Now paint her up and lets see it!Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:She's a BEAST    Looks like you need some new springs for the truck.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:samm!Looks good!ButIYou need a pickup a little more in the color of mine to put that in, it might not be Lincoln red, but its close enough!  Attached Images#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:I wouldn't say something like that. Would I? I don't know. I might. It looks good but I STILL want to see it on the tractor! All kidding aside, I think this is going to be a very handy rig for you. It should save you a lot of time and some backaches too. Well done.
Reply:That is one nice setup for hauling the toys around the ranch.   I am thinking that maybe you might “pimp” it out with some work lights, vice, and a cooler to keep them puppies cold…. Great example of practical engineering… Thanks for sharing
Reply:congrats!!!!!!!!!
Reply:Originally Posted by OldtimerI wouldn't say something like that. Would I? I don't know. I might. It looks good but I STILL want to see it on the tractor! All kidding aside, I think this is going to be a very handy rig for you. It should save you a lot of time and some backaches too. Well done.
Reply:HE DID BOTH!!!!! Attached Images"Any day above ground is a good day"http://www.farmersamm.com/
Reply:What a piss off :PNice work ppl!My Babies: HF Drill pressHF Pipe Bender3   4.5" Black and Decker angle grindersLincoln Electric PROMIG 175that´s it!
Reply:Samm - The wheel removal socket extension, should somehow be supported near the ratchet head.Since you're good at getting things built -  How about a vertical angle with scallops cut out of it to support the extension at various heights?Good Luck
Reply:Originally Posted by denrepSamm - The wheel removal socket extension, should somehow be supported near the ratchet head.Since you're good at getting things built -  How about a vertical angle with scallops cut out of it to support the extension at various heights?Good Luck
Reply:Looks good Sam!!  I think you need to add a little insulation to the cooler section though, hot beer ain't to damn good.....unless you're already drunk and don't realize the difference (been there)  Maybe you should wait and see how this bedliner stuff turns out before painting, it would be perfect if it works DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:Turn that wrench around so the cheater is on the ground and drive the tractor forward. Something will break loose.A butterfly without wings, is just an ugly bug
Reply:Ya know Sam, I just thought of something.'Rules of Projects' paragraph 23.1.4 states: "Whenever building something for a particular piece of equipment, that equipment must be used in the construction of said project."I know you used the Miller Lite and O/A torches but I sure hope you used that engine drive for the welding.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!Originally Posted by duaneb55Ya know Sam, I just thought of something.'Rules of Projects' paragraph 23.1.4 states: "Whenever building something for a particular piece of equipment, that equipment must be used in the construction of said project."I know you used the Miller Lite and O/A torches but I sure hope you used that engine drive for the welding.
Reply:Originally Posted by SandyAnd if he didn't does he forfeit the project or the equipment??
Reply:Originally Posted by duaneb55Equipment of course.  Gets surrendered to the one who caught the infraction.
GMT+8, 2025-12-23 07:17 , Processed in 0.095292 second(s), 18 queries .
