Welding Machine Cart
发表于 2021-9-1 00:11:52 | 显示全部楼层 |阅读模式
You guys have inspired me to build something! I'm not the most original person out there so I had to kinda copy an idea from you guys. I am wanting to put a tig rod organizer on the side of this thing. But for right now im sure my orange crush will be happy to not be crammed in that little junk yellow wagon! The rod organizer can wait till this weekend, or next weekend, or the weekend after! Attached Imagesonly thing worse than an ugly woman is an ugly weld
Reply:finally got my machine moved on the cart last night and got my rod organized. need pvc and a way to mount it to the cart. Attached Imagesonly thing worse than an ugly woman is an ugly weld
Reply:See what you started Samm....Nice job btw lloyedo.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:I like the yellow wagon. tons of room to for junk to pile up all around the welder.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Neat how you made the hooks with the double bend.  Do you do that with heat or a bender??"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Nice job on the cart El_Lloydeo.  Nice layout, wide stance and low CofG.Need an idea for those filler rod holders?http://weldingweb.com/vbb/showthread.php?t=26494Others have done similar arrangements.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Duane, love the set up you have, im going to do something very similar to that. was going to do something else, but i like yours. id like to have a little junk bowl of some sort on mine. like something to put soapstone in or stuff like that. well see. looks like i wont be able to work on it till next weekend. went out and bought the pvc and caps already though.only thing worse than an ugly woman is an ugly weld
Reply:Hi Ya El_Lloydeo nice looking machine and cart. Maybe for the junk bowl something like a metal box or old tool box tacked to the side. I have used old metal tackle boxes that friends were going to throw away.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Nice Job Lloyde,  can you tell me a little about your machine?  Is it a Stick/Tig unit.  I have seen a fewold BIG (500-1000lbs) Airco welders out there for sale, just haven't much about them.
Reply:I dont know a whole bunch about it myself. i bought it used a few years ago and it was in very nice shape and cheap so i bought it. runs pretty darn good too. its an airco 250 heliwelder ac/dc. i really like the way it performs.only thing worse than an ugly woman is an ugly weld
Reply:had a couple hours to kill tonight, still a lot more to do though Attached Imagesonly thing worse than an ugly woman is an ugly weld
Reply:Very nice design El_Lloydeo.  Looks like it took you a little time to build.Did you consider mounting the rack inside the rail to keep the overall width down?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:better be a nice design i kinda stole it from you! haha im actually gonna put another section on the inside of the rail for another row of pvc. did you seperate yours by alloy and diameter both or just alloy?only thing worse than an ugly woman is an ugly weld
Reply:Originally Posted by El_Lloydeobetter be a nice design i kinda stole it from you! haha im actually gonna put another section on the inside of the rail for another row of pvc. did you seperate yours by alloy and diameter both or just alloy?
Reply:i was thinking about even keeping brazing rod in there too. im also thinking about mounting an ammo bracket on there to store tungsten and stuff in it. its my buddy glenns ammo box but he prolly forgot i even have it. we were gonna mount it on a dunebuggy we built last year.only thing worse than an ugly woman is an ugly weld
Reply:Nice lookin kart loydo, but isn't it supposed to be "a square peg in a round hole?"A butterfly without wings, is just an ugly bug
Reply:You could use something like this even if you need multiples.They only cost a few bucks at hobby and sewing supply stores (mine came from Jo-Ann Fabrics).  I have one one the MM200 and a smaller one (you can see it in the first photo) for the plasma cutter consumables.A number of others http://weldingweb.com/vbb/showthread.php?t=23724 have used the same or similar methods for consumable storage.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:3 tungstens..my torch wouldnt even get warm before i made a trip to the grinder...
Reply:No offense here but its actually its PVC PIPE.
Reply:Originally Posted by landmanNo offense here but its actually its PVC PIPE.
Reply:1 1/2" i d pvc. ive been using a tackle box for the cups and everything else. seems to work well. thought about making a tube for short rods too so i can use them up first. maybe i will keep that on top of the fridge or something.only thing worse than an ugly woman is an ugly weld
GMT+8, 2025-12-23 07:21 , Processed in 0.076403 second(s), 18 queries .
