Just do it.
发表于 2021-9-1 00:11:51 | 显示全部楼层 |阅读模式
My brother-in-law needed to replace a heavy worn out wood gate so I decided to weld him up one.  It was made using a Lincoln Weld Pak 140HD mig. Attached Images
Reply:Here's a garden bench made with the same welder.  The flowers and leaves were ordered from kingmetals.com. Attached Images
Reply:Nice.    The best laid schemes ... Gang oft agley ...
Reply:They both look REALLY good"Any day above ground is a good day"http://www.farmersamm.com/
Reply:That's NICE. Both of 'em.
Reply:Agreed both are nice! I would like to see a close up of the welded expanded steel to the frame work, I can never get two of those welds looking the same on that stuff.Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:Great looking work.
GMT+8, 2025-12-23 07:36 , Processed in 0.097533 second(s), 18 queries .
