More stupid questions about things people probably shouldn't do; what will welds look like if you don't use shielding gas? Anyone tried with TIG or MIG?--------------------GMC WLDR 140A Stick Arc cheapskatenow with 90% more burnthrough
Reply:It will look like a splatter then the flame will go out, your tungsten will melt and youll be making a trip to your favorite grinding device.I know cause Ive done it a few times.Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
Reply:the tungsten electrode oxidizes and contaminates the weld with tig with mig it looks like chickensh*t.Thermal Arc 185 TigHTP 200 MigCraftsman O/A1942 Bridgeport Mill12 Ton Hyd PressConsew Walking Foot
Reply:Had a gas problem with a mig welder and the welds looked like swiss cheese and wouldn't hold. Sheilding gas is very inportant.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:TIGTungestionInertGasTrying it any other way is a sure way to absolutly nothing.. ...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Dont worry everyone with a Tig has forgotten to turn on the gas ....youll see what it looks like eventually!
Reply:Originally Posted by BrettDont worry everyone with a Tig has forgotten to turn on the gas ....youll see what it looks like eventually!
Reply:BAD move... NO GAS no TIG
Reply:Turn off your gas and check it out for yourself. Looks terrible.DewayneDixieland WeldingMM350PLincoln 100Some torchesOther misc. tools
Reply:been there, done that. No good.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
Reply:faex, Here's a picture I took of 16 gauge steel I welded with and without filler with no gas. These I did when I found a couple of used Miller TIG welders with problems. When I got the full wide open current problem resolved I sat for a quick minute on each welder using both 3/32 and 1/16 tungsten with no argon, some welds are using 1/16 70s2 and some are no filler, notice the tungsten 3/32 on left and 1/16th on right. Both were grinded before the less than 1 minute weld each, you will notice that the 3/32 has a hump in the middle, well the bench grinder ripped it out of my hand and I had to fight it back from it. I also did not clean the steel before I welded (this was done a month ago).o.c.d. Attached ImagesLast edited by o.c.d.; 02-06-2007 at 11:13 PM. |
