cleaning oil off steel to be painted? Best way.
发表于 2021-9-1 00:11:44 | 显示全部楼层 |阅读模式
Whats the best way to get oil off steel to be painted?ThermalArc 161STL TIG/Stick (160amp)Lincoln weld-pak 100 (fluxcore)4X6 Enco bandsaw10" skillsaw with metal blade for 45degrees (works)4" grinderWeld for fun. Very rare I do it for Money.
Reply:Lacquer thinner, de-greaser,and other solvents, media blasting.....
Reply:One of the few Eastwood product's I actually use Eastwood's After Blast works great, use it every time I soda, or media, blast something. Also use it when I want to be sure the metal is completely clean before I powder coat or paint. Cleans everything off and lightly etches the metal, it is pretty nasty stuff and you don't want to spill any on your garage floor, attacks concrete like a mild muriatic acid would.Millermatic 211 Lincoln Idealarc 250-250, ~500lb water cooled tig
GMT+8, 2025-12-23 07:19 , Processed in 0.094709 second(s), 18 queries .
