Stick or Mig: which is easier
发表于 2021-9-1 00:11:43 | 显示全部楼层 |阅读模式
I have benn mig welding and i also have a stick welder that we are going to hook up. Which is easier and what is the main difference in the technique?ThanksMillermatic 200Linde 295 Amp Stick90 Amp Flux-Core
Reply:If you just have that little HF wirefeed, then you haven't been mig welding, you've been running flux-core... And FCAW and SMAW (stick) have a lot in common, there's slag to chip, you cant push the puddle, etc.Basically, you're going to a bigger, more capable machine and getting your "mig" wire in 14" sticks instead of little spools. Good luck [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:thanksMillermatic 200Linde 295 Amp Stick90 Amp Flux-Core
Reply:Learn to master stick.  Requires better hand hand eye coordination to manipulate the puddle.  Mig has limitations that stick does not.
Reply:yea my dad just bought a stick and i have the hf flux core the i do little things with but i thought stick would be more useful for bigger metalsMillermatic 200Linde 295 Amp Stick90 Amp Flux-Core
Reply:Tig....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:To answer your question in one word, MIG
GMT+8, 2025-12-23 07:19 , Processed in 0.095883 second(s), 18 queries .
