latest project-skate wheels
发表于 2021-9-1 00:11:42 | 显示全部楼层 |阅读模式
Here is my latest creation....I'm  almost positive it will work. Attached ImagesMiller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:does something we cant see yet mount on and turn around those 3 little wheels? what  the hell is it??? nice job getting all those planes lined up...
Reply:I think the 2 key words are "almost positive".  I second the question.  What the h*** is it?
Reply:??? steady rest for a lathe   ???Just my  opinion, not from a book, just from the road.Howes Welding Inc.www.howesweldinginc.com
Reply:My vote is for some form of steady rest.R"I heard that!!"
Reply:I'd guess it's the 'tailstock' end of a welding positioner for pipe.That second shot above almost looks like an old film negative; is it supposed to look like something from "The Twilight Zone"?
Reply:Maybe it takes you into another dimension, like the Stargate thingy?   Have a Jeep Cherokee?  Click Here!
Reply:Looks kike a steady rest, kind of light weight looking, but do not know what it will be used for.Just wondering how you bent the angle iron into a circle, that looks really good.G3miller... 225g, s32p, 250x, 304, 12vs, MSW41     victor o/a thermal dynamics cutmaster 50 lenco panel spotter        hobart hf-boxG3 Farms.....raising cattle, hay, kids and hell, ...oh yeah I'm a fire sprinkler contractor by trade.
Reply:its clearly a Stargate.  it folds space and time, so you can travel to the past/future to any point in the universe. I've only used something like that once before
Reply:Whatever it is, it sure is nice!    I'd like to have one too... wonder what I'd use it for ??MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Flux Capacitor?1.21 Gigawatts!!!!!!
Reply:Oxy moron wrote: its clearly a Stargate. it folds space and time, so you can travel to the past/future to any point in the universe. I've only used something like that once before  This board's depth of experience is amazing.  I figured I was the only one who toured that luminescent green UFO!
Reply:This is bull crap.  I still don't know what it is and it's ticking me off.How long do I have to wait to find out????I don't have a  lot of time, I am impatient. Come one....tell me... tell meeeeeeeeeeeeeLincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Ahem!The Stargate does not take you to other dimensions, it creates a stable worm hole through space that you pass through to other planets in the galaxy!To be able to pinpoint any position in space, you need 6 points of reference, like for example, the 6 sides of a box, the point in the middle at which if you drew a line from them all to the others is the point at which you will arrive, add a 7th point for a reference point to which to travel from, and then add the gate and its many constellation reference point addresses and you have the event horizon to which to pass through!I hope that is as clear as mud! #1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:Dude, way too much TV.Tim Beeker.
Reply:Originally Posted by tnjindDude, way too much TV.
Reply:Gee a rocket scientist.It almost looks like something from President Ray Guns Star Wars Projects,Did anyone guess what the thing actually is or do we sit here wagin at wagin??Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:I'll bet if a hub were placed inside the 3 little wheels that any motion of the hub would be transferred to the bigger outside wheel almos perfectly.If the hub were attached to your foot, the big wheel would be an extension of your foot thru the little wheels, and the fixed arms holding the little wheels to the bigger outside wheel."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Looking back at the title leads one to think it might  have something to do with skating.But looking closer at the THING with the skate wheels I assuming that you might insert some round stock into the center of the thing tighten the thing up on the stock and spin it around while using your cutting torch.Did I win the Brass Ring????????And I was just starting to like the Star Gate ideaCo-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:There was a similar device in another thread on another forum. The one in that thread was a steady rest for a wood lathe. Judging the size by the skate wheels, this iteration is about 1/3rd the diameter of the other.I found the site, click on "Clark Steady Rest":  http://www.theokspindoctor.com/RexLast edited by rode2rouen; 03-22-2009 at 10:46 PM.Reason: found the site
Reply:'Bout the same as a spindle bearing sorta"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Just now noticed it's flat and welded on the bottom, it ain't goin' anywhere"Any day above ground is a good day"http://www.farmersamm.com/
Reply:I don't know sam I kind of like the sci fi explanationCo-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Originally Posted by farmersammI'll bet if a hub were placed inside the 3 little wheels that any motion of the hub would be transferred to the bigger outside wheel almos perfectly.If the hub were attached to your foot, the big wheel would be an extension of your foot thru the little wheels, and the fixed arms holding the little wheels to the bigger outside wheel.
Reply:Originally Posted by Magnetic MechanicOK Ken Dennis, see if you can explain this.  Cause I sure don't understand Sam's explaination.Wagin's gonna leave us hangin' for a day, then hit us with the explanationPretty crafty duuuude"Any day above ground is a good day"http://www.farmersamm.com/
Reply:say sam there's a doggie for sale in the sell forum. I bet the cows would be laughing so hard at it they might give butter.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Originally Posted by weldbeaddoes something we cant see yet mount on and turn around those 3 little wheels? what  the hell is it??? nice job getting all those planes lined up...
Reply:Originally Posted by tessdad??? steady rest for a lathe   ???
Reply:Originally Posted by Oldiron2I'd guess it's the 'tailstock' end of a welding positioner for pipe.That second shot above almost looks like an old film negative; is it supposed to look like something from "The Twilight Zone"?
Reply:Originally Posted by oxy moronits clearly a Stargate.  it folds space and time, so you can travel to the past/future to any point in the universe. I've only used something like that once before
Reply:Originally Posted by G3farmsLooks kike a steady rest, kind of light weight looking, but do not know what it will be used for.Just wondering how you bent the angle iron into a circle, that looks really good.G3
Reply:Originally Posted by DesertRider33Whatever it is, it sure is nice!    I'd like to have one too... wonder what I'd use it for ??
Reply:Originally Posted by Joker11This is bull crap.  I still don't know what it is and it's ticking me off.How long do I have to wait to find out????I don't have a  lot of time, I am impatient. Come one....tell me... tell meeeeeeeeeeeee
Reply:Originally Posted by Ken DennisAhem!The Stargate does not take you to other dimensions, it creates a stable worm hole through space that you pass through to other planets in the galaxy!To be able to pinpoint any position in space, you need 6 points of reference, like for example, the 6 sides of a box, the point in the middle at which if you drew a line from them all to the others is the point at which you will arrive, add a 7th point for a reference point to which to travel from, and then add the gate and its many constellation reference point addresses and you have the event horizon to which to pass through!I hope that is as clear as mud!
Reply:Originally Posted by rode2rouenThere was a similar device in another thread on another forum. The one in that thread was a steady rest for a wood lathe. Judging the size by the skate wheels, this iteration is about 1/3rd the diameter of the other.I found the site, click on "Clark Steady Rest":  http://www.theokspindoctor.com/Rex
Reply:Originally Posted by waginIt is a hollowing steady rest for wood turning lathe.
Reply:Damn,  I guess I'm drunk again...Just realized I've posted like a million replies. Sorry......Damn, just posted another one.Miller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:i dont machine anything, what the hell is a steadirest??foto please if it inuse..
Reply:Originally Posted by weldbeadi dont machine anything, what the hell is a steadirest??foto please if it inuse..
GMT+8, 2025-12-23 07:20 , Processed in 0.094497 second(s), 18 queries .
