Car Port
发表于 2021-9-1 00:11:40 | 显示全部楼层 |阅读模式
Most recent project started last week and coming right along. 18'x16' with some big 4"x10"x .188  tubes for the spans. Now for the picsWelds 7018 DCEP 130amps 1/2 inch base plate to 4"x6"x .250 post.3 days in.5 days in.
Reply:Nice, looks like you could park a tank on top of it.Peter
Reply:Originally Posted by castweldNice, looks like you could park a tank on top of it.Peter
Reply:I like the built up welds on the columns."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Wow thats going to be one VERY sturdy carport.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:You must get a h*ll of a lot of snow where you're at.Or tornadoes.A butterfly without wings, is just an ugly bug
Reply:Originally Posted by Magnetic MechanicYou must get a h*ll of a lot of snow where you're at.Or tornadoes.
Reply:That looks like its going to be more stout than my whole garage/shop!#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:Originally Posted by BruceAnd maybe a couple in it, what are your plans for covering it? I like the easy arching.
Reply:real nice buildup, is that a root two fills and 3 cap stringers?am i seein yer welder sittin on a 6 foot ladder? id knock mine off by 8 am first day if i set it there.....id hang it from the arches...
Reply:Originally Posted by weldbeadreal nice buildup, is that a root two fills and 3 cap stringers?am i seein yer welder sittin on a 6 foot ladder? id knock mine off by 8 am first day if i set it there.....id hang it from the arches...
Reply:And are you duct taped to those two ladders in photo 5 too?Nice work.  Is that as close to the trees on the 'downhill' side as it looks?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:So Cal or Berkley, just kiddin' you, your craftsmanship shows well. Plus your using West Virginia Chrome to keep Miller on the ladder!Bruce The Welding ChefLincoln Weld-Pack 3200 NORWELD StickStanford Hill Farm
Reply:That must be expensive as Hell !!!!!
Reply:Originally Posted by BruceSo Cal or Berkley, just kiddin' you, your craftsmanship shows well. Plus your using West Virginia Chrome to keep Miller on the ladder!
Reply:Originally Posted by Sparky#1That must be expensive as Hell !!!!!
Reply:Not even close!Bruce The Welding ChefLincoln Weld-Pack 3200 NORWELD StickStanford Hill Farm
Reply:Originally Posted by Spaulding MetalsCalifornia, niether. Architects can get a bit crazy sometimes.
Reply:yours is alot lighter than the one i just completed but its looking good.   Did you have any of the tubes pre rolled or just spaced them out and clamped the ends?Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:I like the design and nice welds as well.So, two end "rafters" are bowed downward to onto spacers on top of the 4 x 10's, and then all the central rafters are bowed up to and welded to the 2 x 4 ? strongback that spans the one end curve to the other?   Did that make sense?  So the strongback stays on there?Thanks
Reply:Originally Posted by pulserI like the design and nice welds as well.So, two end "rafters" are bowed downward to onto spacers on top of the 4 x 10's, and then all the central rafters are bowed up to and welded to the 2 x 4 ? strongback that spans the one end curve to the other?   Did that make sense?  So the strongback stays on there?Thanks
Reply:Originally Posted by MetalArchitectYeah us Architects ARE crazy... and always over kill. especially with steel, better over designing than paying for a structural engineer Never me though
Reply:nice work
Reply:Project has been finished but just went by and got some pictures.All of that fer a Volkswagen?? 9-11-2001......We Will Never ForgetRetired desk jockey. Hobby weldor with a little training. Craftsman O/A---Flat, Vert, Ovhd, Horz. Miller Syncrowave 250
Reply:Looks great, is the underside painted?Bruce The Welding ChefLincoln Weld-Pack 3200 NORWELD StickStanford Hill Farm
Reply:No paint. The corrogated roof is grey and the steel is left to rust. Thanks to all for the good feedback
GMT+8, 2025-12-23 07:18 , Processed in 0.093727 second(s), 18 queries .
