7/8th fillets
发表于 2021-9-1 00:11:36 | 显示全部楼层 |阅读模式
Sometimes you just have to follow instructions on the print.  In this case instead of bevelling the ends of the 1.25 inch bars we had to build up a 22mm fillet weld all around ( 7/8 inch)   It reminds me of something Fido deposits on my front lawn once and awhile.  The only reason I can see is that the engineer does not want to check for adequate fusion using ultrasonic inspection.  It is much easier and cost effective to do a visual on the weld. Attached Images
Reply:Originally Posted by lotechmanThe only reason I can see is that the engineer does not want to check for adequate fusion using ultrasonic inspection.
GMT+8, 2025-12-23 07:21 , Processed in 0.089951 second(s), 18 queries .
