Dinosaur Begins
发表于 2021-9-1 00:11:31 | 显示全部楼层 |阅读模式
Just started this evening...1948 Ford PU Window Regulator, Moped center stand  for rear "legs", Lower jaw held tension wheel for Exercise Bike."Good Enough Never Is"MIller AC/DC  ThunderboltHobart HH180, 125EZRiland Cut 40 Plasma oxy/act  outfitTons of "stuff", all treasures to me!
Reply:I can see where you're goin' with itWhere's the rest of the truck??????"Any day above ground is a good day"http://www.farmersamm.com/
Reply:I see the dino!  Somehow I wouldn't have if you hadn't said this is what you are making with the parts.  I have no artistic talent.But....  1948 Ford pickup truck parts are in demand!  You could probably get upwards of $50 for that window actuator on D-Bay and help someone resurrect a dinosaur of a different breed!-MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:Originally Posted by MondoI see the dino!  Somehow I wouldn't have if you hadn't said this is what you are making with the parts.  I have no artistic talent.But....  1948 Ford pickup truck parts are in demand!  You could probably get upwards of $50 for that window actuator on D-Bay and help someone resurrect a dinosaur of a different breed!-Mondo
GMT+8, 2025-12-23 07:20 , Processed in 0.094123 second(s), 18 queries .
