smash and grab grilles
发表于 2021-9-1 00:11:29 | 显示全部楼层 |阅读模式
Hey guys what do you think of my smash and grab grilles that i made for my friends bicycle shop? Attached Images
Reply:Looks nicer than the steel gates you normally see. Almost part of the window design instead of a thick ghetto grill. Nice job.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Nice looking work.  Just asking because I want to know for my own benefit...Are there any national fire code regulations on those sorts of window and door coverings?  Do they have to be removeable in an emergency, in any circumstances?Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:'round here, you have to have quick releases on the inside of the house on residential jobs.
Reply:Generally they have to be operable and able to open with 1 motion to unlach when they are on windows of sleeping areas. Each state adopts a model of the code, usually NFPA 101 life safety code or the international building code. In Ct they are usually activated by a plunger type release on the inside of the wall, when you hit the plunger they unlatch and swing away. You see these a lot in projects and public housing in the inner cities. I spent a few years as a fire inspector and earlier as a welder that installed them, kind of ironic ,huh?"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
GMT+8, 2025-12-23 07:18 , Processed in 0.094325 second(s), 18 queries .
