Science Toy X & XI
发表于 2021-9-1 00:11:28 | 显示全部楼层 |阅读模式
The first picture is of a resonator it is kind of cool. You pluck one golf ball and the other one (of the same length) begins to osculate. The four others do not “hear” those two because they vibrate at different frequencies. The two short ones are cool because you can see the energy get transferred back and forth, meaning when one stops, the other starts. Back and forth they go. So I have 5 dollars in steel and a few bucks in golf balls. They sell nicer ones for $100 in the science catalogs. I’m sure they work better but at a savings of $95 I will take my cheap version.The second picture is a two ball drop. Here is the concept gravity accelerates everything (minus a parachute) at a rate of 9.8 m/s/s. I release the ball at the top of the ramp and it kisses (knocks lightly) the other ball off. The ball that was accelerating down the ramp travels 5-6 feet in the air away from the ramp before it hits the ground. The ball that was nudged off the stand falls pretty much straight down, yet they both hit at the same time.So if you shoot a 30-06 rifle level to the ground and drop a bullet at the same time they hit at the same time. One bullet lands next to you the other ¼ mile down field. Kind of cool Attached Images
Reply:Pictures are in the wrong order.
Reply:Reebs:How do you fasten the golf balls to the rods? They're full of rubberbands and probably don't drill very well. Are the rods just solid mild steel? Diameter?I knew about the bullets, pretty cool; glad you posted it.9-11-2001......We Will Never ForgetRetired desk jockey. Hobby weldor with a little training. Craftsman O/A---Flat, Vert, Ovhd, Horz. Miller Syncrowave 250
Reply:i'm takin a physics class now, and we've already gone over that, i thought that lesson was cooler than most.  another example was soem college students went to the auditorium and rigged up a potato gun or somethingthat was pointed in line with a teddy bear hanging from the ceiling.  when the gun was shot the teddy bear dropped and they would always meet.
Reply:fishon91That is a classic. It is often called "shot the monkey". One of my favorites.Craig in DenverI just drilled a hole in it and pushed it on.The diameter is 3/16 mild steel. Spring steel is what works best but I can not find it.
Reply:you forgot a pic of the teach! LOL
Reply:I'll go tell her.
Reply:where's the milf model?  very cool, i wanna build the sympathetic frequency thingy (thats what i call it, i'm not a scientist)
Reply:hey Moron- you know what MILF stands for?Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Originally Posted by Craig in DenverReebs:How do you fasten the golf balls to the rods? They're full of rubberbands and probably don't drill very well. Are the rods just solid mild steel? Diameter?I knew about the bullets, pretty cool; glad you posted it.
Reply:Reebs and Broccoli1:Thanks. 9-11-2001......We Will Never ForgetRetired desk jockey. Hobby weldor with a little training. Craftsman O/A---Flat, Vert, Ovhd, Horz. Miller Syncrowave 250
Reply:craig you must be as old as me.. its been years since golf balls were made with rubber windings...and balata covers.. just solid plastic now...
Reply:Originally Posted by weldbeadcraig you must be as old as me.. its been years since golf balls were made with rubber windings...and balata covers.. just solid plastic now...
Reply:I drilled too deep in a old ball and it shot nasty *** water in my mouth. Scared the hell out of me. When I was a kid (I'm 46) I used to tear apart my dads tore up g. balls to see how they made them.
Reply:Hey Reebs,How long are the posts for the golf balls?  Does it matter?  I like the idea of one starting when the other stops.  I would think also, that longer posts will vibrate for a longer amount of time.My dad would love that, so I need to make him one.  Any hints on lengths would be appreciated.  I assume it doesn't matter, and if that is the case, then cool.Thanks in advance.
Reply:I will measure it tonight. I do not want to mis lead you the one does not come to a complete stop. You have to watch is closely. I do not want you to make it and be disappointed. Plus it works much better if you hold it in you hand in th middle.
Reply:Craig in Denver... yeah, i know what MILF stands for.  If i wanna say milk, i would have said milK.
Reply:that was Broc, not Craig that posted about the milf crack - next time leave it in upper case and the nanny patrol won't notice Fire!, Fire! Oh wait, that's my torch...Lincoln PT-225 TIGLincoln 175 MIG
Reply:Place fer everything- this thread just ain't it Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:pssst, as Reebs found out, -some- golf balls are or may be filled with pressurized liquids.You really shouldn't drill into them.  http://en.wikipedia.org/wiki/Golf_ball  The best laid schemes ... Gang oft agley ...
Reply:The rod lenghts are 24" 18" and 14".Thanks for asking
Reply:MILFS are cool.
Reply:Reebs,thanks for the dimensions.  I have to go out to the scrap heap and see what I can scrounge up.  I think I might even have some old golf balls.  Left over from making them into bell strikers.Thanks again.
Reply:opps, my bad.  apologies to Craig in denver.
GMT+8, 2025-12-23 07:22 , Processed in 0.090635 second(s), 18 queries .
