Money Job for local MachineShop.
发表于 2021-9-1 00:11:28 | 显示全部楼层 |阅读模式
So you don't think I just play With Deer.....lol Here is a job from local machine shop. 11 Brackets for some type of laser measuring fixture.  All Tig work. They made the jig for the job. Any Comments welcome Thanks Red. Attached ImagesLincoln Percision tig 225 (Water cooled)Lincoln 350MP Power mig (with spool gun )Lincoln GXT 250 With Tig  ModuleLincoln Ln-25 Pro Dual PowerCentury 50 plasma cutter.now Lincoln .
Reply:What did you get paid for each bracket?"Good Enough Never Is"MIller AC/DC  ThunderboltHobart HH180, 125EZRiland Cut 40 Plasma oxy/act  outfitTons of "stuff", all treasures to me!
Reply:Looks good.. I've done alot of piece work for a local machine shop.. That can get to be good money once you get your steps down.Common sense in an uncommon degree is what the world calls wisdom.
Reply:I do some piece work for a machine shop too.  Its nice stuff to work with and good money. Worse I have to do is clean oil off.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Does anybody know where to buy those vise grip C-clamps with pivoting tips?Good job.
Reply:Bensweld,Every local welding supply shop that I have been to has them. You probably won't find them at The Home Depot. Maybe, but probably not.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Hillco, It was right at $1.22 an Inch. Cheap I know , but I really don't pay much for consumables.($30 for a refill of Argon bottle and about $2.00 a pound for rod, and a gal per. hour for the gen.) If you figure by hour it's about Union wage for a pipe fitter.Plus I don't have to make the jigs so I save time there as well.I make out Pretty good. The only problem is it comes and goes, sometimes I get allot of work.....some times it's 3/4 weeks be for something come in.DavidR, the first thing I added was a parts cleaner.......cutting oil.Bensweld, I got mine at the local welding shop.........I've learned you don't cheap on your clamps.  Thanks for the comments  Red.Lincoln Percision tig 225 (Water cooled)Lincoln 350MP Power mig (with spool gun )Lincoln GXT 250 With Tig  ModuleLincoln Ln-25 Pro Dual PowerCentury 50 plasma cutter.now Lincoln .
Reply:That's not bad considering they provided the jig, and the bolts align the pieces...it pretty much shoot and go, and your work looks very good, so the word does get around!"Good Enough Never Is"MIller AC/DC  ThunderboltHobart HH180, 125EZRiland Cut 40 Plasma oxy/act  outfitTons of "stuff", all treasures to me!
Reply:Next you will need a positioner.  DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:DavidR, It's funny you should say that. , They had a positioner that sat in a corner of there shop that wasn't used in like 8/9 years.At one time they owed me like $250.00 for a job I did , well I asked about the thing.They said they would sell it but it wouldn't be cheap.Ended up I gave them $25.00 and called it even for the $250.00. What a steal.Even told them it was to cheap and that I'd give more because I felt like I was stealing........He said no, I told you what I thought and that what it is regardless. Will post a pic if you like.Red. Hillco, yep I even get to add my input on how it's made / setup to aid in the welding proses.Can't beat it with a stick.Red.Last edited by Big Red One.; 04-03-2009 at 07:45 AM.Lincoln Percision tig 225 (Water cooled)Lincoln 350MP Power mig (with spool gun )Lincoln GXT 250 With Tig  ModuleLincoln Ln-25 Pro Dual PowerCentury 50 plasma cutter.now Lincoln .
GMT+8, 2025-12-23 07:22 , Processed in 0.065750 second(s), 18 queries .
