rod suggestions for Harley engine cases?
发表于 2021-9-1 00:11:27 | 显示全部楼层 |阅读模式
Hey Guys, got to build up some busted out bolt holes and whatnot, then remachine on somebody's old sportster engine case.  Wondering what the best rod for this is....i'll be using TIG...Thanks in advance,Chris
Reply:clean, clean, clean. then 5356. Those old ironhead cases usually weld pretty good. Good Luck, Adam
Reply:Originally Posted by 72sportyclean, clean, clean. then 5356. Those old ironhead cases usually weld pretty good. Good Luck, Adam
GMT+8, 2025-12-23 07:17 , Processed in 0.090675 second(s), 18 queries .
