Shipping
发表于 2021-9-1 00:11:23 | 显示全部楼层 |阅读模式
I bought a Miller Trailblazer from out of state and I was wondering if I could ship it in a refrigerated truck. 34 degrees. It would save me a ton of $.
Reply:If you can park it outside covered by a tarp in the wintertime, it will be ok to ship in a refrigerated truck.Enjoy your new welder.I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:Thats what I figured, there are a lot of places colder than 34 degrees...
Reply:hell id say do itLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:You must not live in ohio, it stays under 34 for months on end here. Id say do it [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:You might was to blow hot air through it when you warm it back up to avoid condensation.  Use a hair dryer maybe, or just crank it up and let it run until it's warm.Dynasty200DX w/coolmate1MM210MM VintageESAB miniarc161ltsLincoln AC225Victor O/A, Smith AW1ACutmaster 81IR 2475N7.5FPRage3Jancy USA1019" SBAEAD-200LE
Reply:He11 my lincoln runs when its -20 or colder than gets parked back in the cold shed only thing that happens is choke cable freezes so we just unhook it from november to marchMillermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
Reply:If you take it out of the truck and the temp/dew point is close then just let it set for about 12 hours before you put the power to it.  The only danger is condensation caused by taking a cold soaked welder out of a refigerated truck and placing it in a warm, humid atmosphere.  You will be ok as long as you don't fire it up when you still see condensation forming on it.  Like I said, 12 hours in the ambient temp and you should be fine.Lincoln Pro Mig 180Everlast PowerARC 200
Reply:Be sure the USDA inspector doesn't mistake it for a pig. Did I post that? Shame shame Congratulations on your purchase, Wylie Coyote Couldn't the Road Runner, or ACME,  help you with that move? Last edited by denrep; 08-15-2011 at 01:27 AM.
Reply:Thx everyone, hope I can put the deal together.
GMT+8, 2025-12-23 08:52 , Processed in 0.129993 second(s), 18 queries .
