Uber-newbie question..
发表于 2021-9-1 00:11:22 | 显示全部楼层 |阅读模式
Ok guys-I just bought a Hobart Handler 187 and just had a question..Can I run this thing without using gas or do I need the gas as well?ThanksJeff - the UberNewb.
Reply:You can run it without gas using flux core wire. Just read the instructions on polarity in the manual.
Reply:Thank you. I don't have possession of it yet, should be here next week.
Reply:mig means inert gas coverage..this is the flux that protects the weld from oxidation..it is best used indoors..the wire is solid..fluxcore is a tubular wire with flux inside very similar/opposite  to stick electrodes..it is used for outdoors since the gas wont blow away..good luck.
Reply:You can download a manual from the following link and read up about your new machine before it arrives.  It might answer some more questions that will surely arise.Link: http://www.hobartwelders.com/om/6digit/o228187b_hob.pdf
Reply:Thanks guys!
GMT+8, 2025-12-23 07:17 , Processed in 0.090940 second(s), 18 queries .
