rod holder
发表于 2021-9-1 00:11:18 | 显示全部楼层 |阅读模式
check it out Attached Images
Reply:A maybe 3" footprint on your shop space.  Cool !!"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Nice idea and space saver. Sure beats them just laying around and having to sort them out.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Dude, I am stealing your idea!
Reply:Why are all the good ideas taken already? That is way cool. I have the blue store bought ones and they are pretty slim, but that beats all.The rack is even cooler!Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:GREAT use of otherwise unusable space flentyewelding.  Nice job.Not to hijack but here's what I did recently to keep it a little closer to the 'point of use'.  Still need to get the filler rod holders labeled same as you have though. Attached ImagesMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:That's another way cool idea. Are those just conduit clamps on the bottom?Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by Joker11That's another way cool idea. Are those just conduit clamps on the bottom?
Reply:Here's mine!!! I like the idea on the wall also and Duanes too. I don't like chains I wanted something more solid holding the tank. I can roll it into my trailer without the tank               shifting. Attached ImagesLast edited by hytekredneck; 01-26-2009 at 01:46 AM.Reason: spell It's not what you can buy, it's what you can build that matters
Reply:Flentyewelding:   Looks really nice.  I'm curious- why are they spaced so far apart?  Was it just because you only wanted 6 tubes and decided to use all that space behind the door?Lincoln AC225 & MigPak 140, Lincoln Magnum SpoolGun, Miller Spectrum 375-X Plasma, Syncrowave 200 TIG, Millermatic 252 MIG, Miller Digital Elite, General 7x12" horiz/vert bandsaw, 3' box/pan brake, 20 ton press, milling machine, 12x28 lathe, etc.
Reply:yeah i wanted it to take up the space between the door and the garage door
Reply:Originally Posted by flentyeweldingyeah i wanted it to take up the space between the door and the garage door
Reply:I'm never too old to learn.  Great ideas.  I'm a firm believer is using all space to a maximum.  Love these ideas.
Reply:Originally Posted by hytekredneckHere's mine!!! I like the idea on the wall also and Duanes too. I don't like chains I wanted something more solid holding the tank. I can roll it into my trailer without the tank               shifting.
Reply:i use miller
Reply:Nice idea, but why so long of tubes?American by birth Southern by the Grace of God
Reply:Originally Posted by 74fencerNice idea, but why so long of tubes?
Reply:Originally Posted by rode2rouenTIG filler metal is commonly sold in 3' lengths.I made the holder out of a 6" x 18" sheet of 16ga. I had in the pile. A 90 degree bend and it bolts to existing holes in the cabinet sides. Using 7 holes now with room for 7 more.Rex
GMT+8, 2025-12-23 07:18 , Processed in 0.104419 second(s), 18 queries .
