modified lock pliers
发表于 2021-9-1 00:11:17 | 显示全部楼层 |阅读模式
Bought six HF lock pliers (notice I didn't say Vice Grips!) to transform into special purpose,, light duty occasional use tools. I am clamping ATV head with vacuum attachment so that while porting it will pick up most of the chips, and clear ports so I can see what I'm doing. Attached Images
Reply:That's cool.  I can see a lot of uses for it"Any day above ground is a good day"http://www.farmersamm.com/
Reply:what process did you use to weld those, looks like tig welding no?
Reply:Originally Posted by jeeperwhat process did you use to weld those, looks like tig welding no?
Reply:I like your Idea......may have to copy it if you don't mind.......Great looking welds as well. Red.Lincoln Percision tig 225 (Water cooled)Lincoln 350MP Power mig (with spool gun )Lincoln GXT 250 With Tig  ModuleLincoln Ln-25 Pro Dual PowerCentury 50 plasma cutter.now Lincoln .
Reply:Good idea!!!! Those will come in handy for lots of projects. Also nice lookin' welds.I keep finding old American made C-clamps at yard sales and auctions. I've found you can never have too many.                                                    MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Originally Posted by Big Red One.I like your Idea......may have to copy it if you don't mind.......Great looking welds as well. Red.
Reply:Good idea with the locking clamps,i like how you can adjust the tips in or out.Lincoln 225 ACLincoln Mig Pak 15Lincoln Mig Pak 10Purox Oxy-Acet Outfit20 Ton PressHonda Generator
Reply:I like that.  Well done!
Reply:Yeah baby!Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
GMT+8, 2025-12-23 08:52 , Processed in 0.117739 second(s), 18 queries .
