Aluminum battery box
发表于 2021-9-1 00:11:13 | 显示全部楼层 |阅读模式
Here's another quick job I did recently.  It's 13" x 10" x 10".  I prepped the aluimnum before  tacking it together so it would look a little sharper.  My settings were about 120 amps, # 3 on the dig, 3/32 green tungsten and 1/8" filler rod.Not some of my best welds, but they will fly. Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:Nice job Brainfarth.  I can only wish my welds looked half that good.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:nice job....looks nice wish I had a high freq so I can mess with some aluminum  one of these daysIf it's too . get an office jobLincoln wp225g7 Lincoln 250 idealarcFrankenstein O/A set-up Weld-tech  tig set-upLincoln sp 175 plus profax  arc gouger
Reply:120 amps and 3/32" green raises the question, how thick is the alum? What kind of battery is 13 x 10 x 10? Vehicle?OBTW: Nicer welds than I can make. 9-11-2001......We Will Never ForgetRetired desk jockey. Hobby weldor with a little training. Craftsman O/A---Flat, Vert, Ovhd, Horz. Miller Syncrowave 250
Reply:The aluminum was .120 thick and the battery box is for a drag racer.  I didn't use any hi-freq on this one.  Just AC.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Looks good, nice work.Miller Dynasty 200DX Tig Welder
GMT+8, 2025-12-23 07:36 , Processed in 0.101084 second(s), 18 queries .
