Sign Job
发表于 2021-9-1 00:11:13 | 显示全部楼层 |阅读模式
So, after 2 months we finially have the sign up and running.  We were contracted to do the structural welding and ended up overseeing the whole project.   The sign was erected while the old one was still standing.  It was a real bear tearing down the old one with the new one in the way.  The new one specs out at 54' tall and about 27' wide.  We put 30" pipe 13' down in the ground with 7' sticking out.  That was then welded to a 18" pipe with 1/2" plates to adapt to the 30" pipe.  Unfortunately I dont have any pictures of the welds, but I have tons of the sign.  The screens on the new sign are 10' x 18' and ran 200k.  The whole sign was pretty spendy... I think over 500k. Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:Here's some more photos Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:That's some kinda sign!!Cost of signage always blows me away"Any day above ground is a good day"http://www.farmersamm.com/
Reply:I take it that's letters and everything?500K?  That's about 1 weeks take for the casino.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:What recession???Nice interesting job there. They say when times are tough it still pays to advertise. They also sayy that only half your advertising works but you can never tell which half."One of the things we have to be thankful for is that we don't get as much government as we pay for." (Charles Kettering)Mitch 180 (NZ)Lincoln SAM-400-220 + ?-400 Fordson Major + 2 x Tractapac Humber 80 + Procut 40 PlasmaMiller Spectrum 375
Reply:big-assed sign, gonna catch some wind...
Reply:NIce stuff!  Lotsa big welding.   Overhead for the plates on top of the pipe in the ground?David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:That's a pretty big one! Did you guys fabricate the whole sign, or just do the erection? Those LED message centers are HUGE! I've never dealt with any quite that big. Nice looking sign! I would guess the casino paid closer to $1,000,000 than $500,000. $500,000 would just barely cover the material costs and labor involved in a sign like that.Miller EconotigCutmaster 38Yes ma'am, that IS a screwdriver in my pocket!
Reply:The 18" pipes had plates that had an ID for the 18" and an OD for the ID of the 30" pipes.  There were 3 plates at about 16" apart. The top plate was slightly larger so it wouldnt fall in and that is where they called out for 1/4" fillet.  Then at 4 points I cut access for plug welds in the 30" pipe.  I would scan the print, but our scanner is lost in the network somewhere.  We only erected the main parts of the sign.  It would have been nice to be in on the fabrication part of things.  There have been talks about another one going up on the coast and we would have control of the project.  The aluminum sections of it would be outsourced.  Oh yeah, the LED screens are 8mm (actually larger, but it's a new diaginal type so they can pull off the apearance of a smaller dot pitch).Common sense in an uncommon degree is what the world calls wisdom.
Reply:I forgot to mention that we kept the old display message center.  It measures 13' x 2' x apporx 4' tall.  It was setup for telephone control and has 4224 lamps.. I can make a smokin' deal on it. Common sense in an uncommon degree is what the world calls wisdom.
Reply:Nice project!  Is that you up on top waving to the crowd below??-MondoMember, AWSLincoln ProMIG 140Lincoln AC TombstoneCraftsman Lathe 12 x 24 c1935Atlas MFC Horizontal MillCraftsman Commercial Lathe 12 x 36 c1970- - - I'll just keep on keepin' on.
Reply:No, I'm not in that photo... But I was up on top of the big one a few times..And here are some photos that were taken of me while I was setting the LED displays while they were being hung by the crane. Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:Nice boom truck.   I have one just like it. BEST TOOL I OWN.  That sign came out nice.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Originally Posted by duaneb55I take it that's letters and everything?500K?  That's about 1 weeks take for the casino.
Reply:Brainfarth,Howdy neighbor!  Nice work on the sign!!  I usually try to drive right by that place, (or I wouldn't have anything left for the Tool Crib!!TimA rich man is not the one who has the most but instead one who needs theleast. Retired IUEC local 19AK Bush pilot,  Chaplain  CMA Chapt 26victor torchesMiller110v migDynasty 200dx (new in Dec 08)Hypertherm PM-45MM-252 (new 2/09)
GMT+8, 2025-12-23 07:18 , Processed in 0.092289 second(s), 18 queries .
