Guess II
发表于 2021-9-1 00:11:13 | 显示全部楼层 |阅读模式
I've never made one of these before, so I wanted to know if anyone had a clue as to what this is. Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:Well that brass adapter looks like 1-1/2" NST (fire hose) thread but beyond that. . .MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Yeh, that's the ole garden hose to exhaust adapter. It's used for flushing mufflers.
Reply:I'm thinkin' the brass bit is garden hose size, based on the size of the pallet boards.The rest of it looks like was going to be an exhaust megaphone for a motorcycle.RexYer too fast for me, Sandy!
Reply:is it for blasting through some type of drain with water?
Reply:Beer bong!!!! It's not what you can buy, it's what you can build that matters
Reply:I'm going to guess it's for putting exhaust into something.... like a propane tank you're going to cut.HH 187Miller Bluestar1EAHP AlphaTig 200X
Reply:a new hat for the tin man
Reply:Originally Posted by hytekredneckBeer bong!!!!
Reply:Cavalry bugle? Expansion chamber for an R/C bench racer? Candy chute to fit the magazine on a semi & fully automatic pez dispenser?City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:is it for a dunebuggy? or maybe a 2stroke dirty bike or something?I break things for a living...
Reply:A doit yourself mouth suctioned penjs enlarger!Did I win?#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:Haha, great guesses... We joking about the beer bong earlier.. But we were fresh out of beer!One side is a garden hose fitting and the other side is a little over 3.5" in diameter.  Also, it is lined with aluminum heat tape.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Originally Posted by BrainfarthHaha, great guesses... We joking about the beer bong earlier.. But we were fresh out of beer!One side is a garden hose fitting and the other side is a little over 3.5" in diameter.  Also, it is lined with aluminum heat tape.
Reply:looks like someone is trying to run his car indoors.  if you stuck this thing onto a muffler, and hook up the long garden hose, and run the exhaust outside.i guess they could have just gotten long 4 inch dryer duct for that.
Reply:muffler bearing or a relican rod.JunkYard Tools .com
Reply:Let's see...Looking at the homemade construction and the angle of the offset and the rudimentary construction out of everyday materials,  I would think that it be for something or some process of manufacturing that might be possibly restricted by the federal government...Hmmm....The collecting tube off a moonshine still?Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:An exhaust pipe for a stanley steamer or a steam pipe hookup from a boiler or a new leg for a pirate with a hunched back with the latest technology in screw on feet?    Felon
Reply:You guys were getting closer.. but I have to give it away..... The guy says he can wipe out an entire colony in less than 10 minutes. Attached ImagesCommon sense in an uncommon degree is what the world calls wisdom.
Reply:I don't see how the engine will even run with such a small outlet.Try running a V8 thru exhaust that small?Ain't happening....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
GMT+8, 2025-12-23 07:24 , Processed in 0.095195 second(s), 18 queries .
