Antenna brackets. Made from 1" and 3/8" plate. 1 1/4" Holes bored in my lathe and welded with my MM185 w/CO2 and Inweld Dual Shield .035 fluxcore wire...Bobhttp://www.inweldcorporation.com/datasheets/E71T-1.pdf Attached ImagesBob WrightSalem, Ohio Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Reply:Nice work aametalmaster.What's the application? Does it get welded or bolted to a support structure?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55Nice work aametalmaster.What's the application? Does it get welded or bolted to a support structure?
Reply:Sweet.simple.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Ya that looks good heavy duty for sure, hope he had you made him a couple of those and he has some mean framing because that mast pipe is HUGE Wish I had mounts like that for my tower to house bracket, the factory mount I have is cheesy junk compared to that.Lincoln 225 Tombstone,Miller Big 20,Hobart 180,150' Argon,A/D hobart hood 22 Ton Log splitter,79 F350 dump eats 4.75 TONS and still turns cutters,grinders,And a Hypertherm POWERMAX 30 |
