Set and adjust the parameters of intermediate frequency spot welding machine
管理员
Rank: 9Rank: 9Rank: 9
发表于 2021-6-10 16:48:37 | 显示全部楼层 |阅读模式
图文
图文封面:
How to set and adjust the main welding parameters of medium frequency spot welder? Some manufacturers produce many kinds of products. The thickness and material of different products are different. Different main parameters need to be set when welding products with different materials and thickness. So what are the main parameters of medium frequency spot welding machine? General electric small series to explain to you, such as electrode pressure, working current and power on time, as well as other preloading time, maintenance time, intermittent time are not very important, just some auxiliary main parameters.
The main welding parameters of medium frequency spot welding machine are usually selected according to the material and thickness of the product workpiece and the welding standard of this material. First of all, it is necessary to determine the end face shape and size of the electrode of the spot welding machine, and then select the electrode pressure, welding current and power on time. Spot welding is usually divided into hard specification and soft specification. Hard specification is current plus short time in large work, while soft specification is current plus long time in small work.。
Start the trial welding from the small current in the work, slowly increase the current in the work until there is splashing, and then moderately reduce the current in the work to no splashing, check whether the pulling and shearing degree of single point, the diameter of solder joint and the penetration can meet the requirements, and moderately adjust the current in the work or the welding time until the requirements are met.
With the increase of the thickness of the plate, it is necessary to increase the current in the work, and the way to increase the current in the work is generally to adjust the voltage (generally, when the resistance is fixed, the higher the voltage, the greater the current in the work), or increase the power on time in the state of constant current, which can also improve the heat input, so as to obtain better welding effect.
Guangdong Pudian Automation Technology Co., Ltd. is a professional manufacturer of welding equipment. For 16 years, it has focused on R & D and sales of spot welding machine, laser welding machine, non-standard automatic welding machine, welding robot and other welding equipment. Pudian welding machine focuses on the field of metal welding, saving energy and reducing consumption, improving welding quality and improving welding efficiency, Reducing the cost of welding is our fundamental service to customers.
Free proofing hotline: +86-13553885280
Address: Zone B, 1st floor, C-1, No. 6, industrial North Road, industrial park, Songshan Lake high tech Industrial Development Zone, Dongguan, Guangdong Province, Tel: +86-769-81767569
本帖子中包含更多资源
您需要 登录 才可以下载或查看,没有帐号?立即注册
x
GMT+8, 2025-12-17 04:10 , Processed in 0.111329 second(s), 21 queries .
