Here's a Guy's Bar-B-Que
发表于 2021-9-1 00:11:11 | 显示全部楼层 |阅读模式
Got to hand it to the guy who built this.  Check the temp gauge out, mounted where the thermostat housing would be.  Love them small block chevy's.  Got a 1965 327 cid sittin' in the barn waiting to be put in something.  Got the 202 heads too. Attached Images
Reply:Now that is freakin cool! Lincoln 225 ACLincoln Mig Pak 15Lincoln Mig Pak 10Purox Oxy-Acet Outfit20 Ton PressHonda Generator
Reply:And it's even on an engine stand!Lincoln 225 ACLincoln Mig Pak 15Lincoln Mig Pak 10Purox Oxy-Acet Outfit20 Ton PressHonda Generator
Reply:That is super cool!!! Must be pretty good with welding some cast iron. Wish I could do that.
Reply:I started one of those, but it got put on the back burner... http://weldingweb.com/vbb/showthread.php?t=13284Maybe this summer when the cash is flowing a little more.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Really Great!  I thought about making my Stainless Steel Roadster so the engine compartment was a grill...Lift the hood, exhaust stacks, etc...but this is even cooler!"Good Enough Never Is"MIller AC/DC  ThunderboltHobart HH180, 125EZRiland Cut 40 Plasma oxy/act  outfitTons of "stuff", all treasures to me!
Reply:Where does the smoke come out?  The exhaust or the air cleaner?  So cool!
Reply:That's wild.  Must take a pretty good arm to lift the "lid""Any day above ground is a good day"http://www.farmersamm.com/
Reply:that little chevy grill is cute.    I need to find a pic of a MAN sized V-8 made into a grill.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:3408 CAT V-8 BBQVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Originally Posted by farmersammThat's wild.  Must take a pretty good arm to lift the "lid"
Reply:I have been  wondering what to do with old 4 bolt main truck engine I have sitting by my barn. I would imagine with a plasma torch and some imagination you could lighten that manifold and heads so they don't weigh so much.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Originally Posted by specterI would imagine with a plasma torch and some imagination you could lighten that manifold and heads so they don't weigh so much.
Reply:Yeah, the heads do weigh things down quite at bit.. it's not a kids toy and will lop off a finger in a blink of an eye.  I tried to find some junk aluminum heads at the time with no luck.  And there's not a lot of room below the grill for charcoal, so unless you want to cook right in the middle of the grill, gas seems to be the only option.Common sense in an uncommon degree is what the world calls wisdom.
Reply:I'd also like to know how he cut the cylinders out of the block.  That must have been a neat trick.  I'm with Samm, lifting the lid must take a chain hoist.
Reply:As far as crud goes, a good burning then power wash and then spray it down good with oven cleaner, let set then another power wash ought to do it!#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:That is sweetMiller Dynasty 200DX Tig Welder
Reply:Originally Posted by paweldorI'd also like to know how he cut the cylinders out of the block.  That must have been a neat trick.  I'm with Samm, lifting the lid must take a chain hoist.
Reply:Tim The Tool Man Taylor would be mighty proud of those two units.  Awesome.
Reply:Originally Posted by Tamper84Do you suppose he just started with one of those dummy blocks?
Reply:They both need a pair of boobs and maybe some legs and they'll be a true man's BBQ.The second appears to be a 3412.  I've got a few 3512's, I wonder if I could make them into a BBQ.  Our EMD's might be easier because they have steel blocks while the Cat's are cast iron.
GMT+8, 2025-12-25 10:31 , Processed in 0.164451 second(s), 18 queries .
