utility wagon / yard cart
发表于 2021-9-1 00:11:07 | 显示全部楼层 |阅读模式
This is a utility wagon I did some modifications on.  I use this mostly for pulling my fishing and hunting equipment behind my four wheeler.  I live about 2 miles from a large river, abundant with catfish, so this is really handy for packing everything in for a day fishing trip.The first thing I did was replace the small wheelbarrow type tires with some used lawn mower tires and wheels.  I used a piece of 3/4 cold rolled for an axle and mounted pillow block bearings on each end.  Ideally, 4 bearings should have been used, but the terrain I'm on is mostly mud and sand so the tires don't "scoot" too bad on turns. I made the tailgate more usable today by making it hinge down with secure latches on top.  All the parts I used were misc. pieces I had - mostly bolts and some various bushings and spacers.  I had to buy the 2 springs to hold the latches shut.Next post.
Reply:Nice fix! Good jobStrive For Perfection
Reply:This is my fishing rod box.  I break down my poles and this box keeps them from getting broken.  Under the poles I have room for misc. items.I can't take a fishing trip without a good supply of beverages, so naturally a cooler is in order.Also lawn chairs are a necessity.  The empty corner holds my tackle boxes.  They are in my truck right now and I didn't feel like getting them out just for picture purposes.  Just imagine 2 tackle boxes in the empty spot with room on top of them for a big stringer of fish!  Last edited by Road Warrior; 04-15-2009 at 10:44 PM.
Reply:Nice work,i have a similar size atv trailer that i use to haul firewood over to my basement window,very handy.Lincoln 225 ACLincoln Mig Pak 15Lincoln Mig Pak 10Purox Oxy-Acet Outfit20 Ton PressHonda Generator
Reply:Originally Posted by BrooksNice fix! Good job
Reply:that sure is one tough looking cart, you need to put this badge on it:
Reply:here ya go   Attached Images
Reply:Originally Posted by oxy moronhere ya go
GMT+8, 2025-12-23 10:48 , Processed in 0.130719 second(s), 18 queries .
